batch plotting - multiple layouts
Message 1 of 10
Hello. I use AutoCAD Lt 2022. Something has gone awry with bath plotting multiple layouts to a single PDF file. It plots every layout as a single PDF. This wasn't an issue until just recently, since I uninstalled and subsequently re-installed the program. There is nothing in the settings I can see that i might change in order to plot layouts to a single PDF as I used to do before re-installing the program. I've checked the help section and found nothing. I'd greatly appreciate some help with this.
Replies (9)
Message 2 of 10
cadffm
it is in your publish options, in the upper right corner of your PUBLISH dialog.
While "Publish to:" is set to PDF, you can change these setting, also too "multi sheet"
[F1] - Publish options
Sebastian
Message 3 of 10
Hi. Thanks for the prompt reply. Yes, of course I assumed that’s where I would find the option, but as you can see in the screen shot below, I am unable to select the “Publish options” feature”. Do you know why that might be?
[cid:image002.png@01D7D48C.6972CC40]
Regrads,
Sylvain Thibault
Message 4 of 10
Sorry. Here's the screenshot I referred to in my initial reply.
Message 5 of 10
cadffm
Nothing attached, please try it again.
Come over here an reply, attach or insert your Screenshot.
https://forums.autodesk.com/t5/autocad-lt-forum/batch-plotting-multiple-layouts/m-p/10743333#M192330
But before, doublecheck my last answer, be sure you read and test all.
I guess i already answerd your situation and goe to solve it.
Upload your screenshot, if Publish to is set to pdf.
Sebastian
Message 6 of 10
cadffm
Thank you for your screenshot, but as is wrote in my first answer...
Sebastian
Message 7 of 10
Ah. OK. I overlooked that reference to "Publish To" having to be set to PDF. It's fine now.
Thank you very much.
Have a great rest of your day.
Message 8 of 10
cadffm
You're welcome
Sebastian
Message 9 of 10
pendean
Community Legend
Community Legend
You will never EVER get what you want with this option
You have to opt for one of the PDF options in that pulldown instead.
Message 10 of 10
Yes, thank you. As you can see in the previous posts to this conversation, the issue has been resolved. Thanks for taking the time to respond, though.
