AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Automatic z-value when drawing new lines
6 REPLIES 6
t.brouwershaven
3224 Views, 6 Replies
Hello all,
I've searched these forums but i cannot seem to find the right answer.
The issue i'm having is this:
I'm editing a drawing. In this drawing, every object has a z-value or elevation of -366.
I already got my entire drawing to a elevation of 0 by using "QSELECT" and edit every elevation to 0.
But when drawing new lines, the elevation of these lines will also be -366.
When using the "ELEVATION" command and setting its value to 366 all the elevation values will be 0.
When looking through the properties panel, it says normal z-value -366.
I cannot find a solution to put all z-values, current and new, to be 0.
Can you help me, because editing every line after drawing is pretty annoying.
Thanks in advance
6 REPLIES 6
vinodkl
in reply to: t.brouwershaven
Here are the things to check:
  • Check if your UCS is set to "WORLD". If not Type in "UCS" and then select "WORLD"
  • Check if OSNAPZ is set "0".
You are still facing the problem? Then please provide us the drawing for testing.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
steven-g
It sounds like your UCS is set at Z=-366, try setting your UCS to 'world'. Just type 'UCS' <enter> followed by 'w' <enter>, does that make things better? If not then post your dwg and we can see what is going on, 'elevation' is a variable and if it is set to anything other than zero then new objects are drawn using that elevation value for the Z height (relative to the world UCS).
steven-g
in reply to: vinodkl
There is no 'osnapz' in LT 😁
Thank you for your help.
I aligned my UCS to some objects to make drawing easier, but this object was also at z-value -366.
Resetting my UCS to "world" did it.
steven-g
Yup that would do it, new objects are always drawn on the current UCS, but the properties panel will always show coordinates relative to the world UCS.
vinodkl
in reply to: steven-g
I totally forgot that I'm LT forum😆
Technology Administrators
