When trying to trim lines it doesnt always go to the nearest line and takes out the line completely, better explained in the attache video, it does this on all drawings not just on this drawing.
Anyhelp much appreciated.
Solved by cadffm. Go to Solution.
One million dollar question (check you capture)
Is it also a problem a bit nearer to 0,0,0?
You drawing far away from 0,0,0 and this is a problem for a pc, the software and math.
Coord: X=2650047604 Y=2064166855 means ~3359106731 units away from 0,0,0
Read this if you need to draw there
https://blogs.autodesk.com/autocad/working-large-coordinates-in-autocad/
or move all to 0,0,0 if not.
Sebastian
