I've received a drawing where all the objects are on the same layer but in different colors. Is the some sort of "select all objects of XXX color". I don't really know how to use "Filters" or how they would work for selecting all objects of the same color.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Solved by pendean. Go to Solution.
Solved by rkmcswain. Go to Solution.
hello,
Quickselect selects only objects that are set to a specific color. If different layers have for instance magenta as color, and those object's color is set to "bylayer", I can't select them by doing a quickselect choosing color as property and magenta as value.
So how can I do this?
thanks
FILTER is too complicated to select every objects of a color. And not even sure it can.
SELECTSIMILAR with SELECTSIMILARMODE set to 1 (colour) does not select object color inherited "BYLAYER". So if I use the command on a object that have its color inherited by its layer, autocad select every object of color set to "BYLAYER" which are every object in my drawing.
with Filter it is easy to select all objects with one or a list of colors!
You need more experience to use this command, thats all.
But: There is no command to select all objects which displays in a color,
all commands can only filter object data and the object data is bylayer OR (color number).
For this goal you need a tool, a program, there is no onboard solution.
A color can come by object-color, from a layer(bylayer) or by a block-structure(byblock),
or by a plotstyle(!)
Just an extra tool is able to to this selection.
Sorry , i can not offer such a tool, but for the simple <color or colorfromlayer> situation, you should be able to find one - BUT NOT FOR LT versions.
Sebastian
