AutoCAD LT Forum
AutoCAD LT problem
9 REPLIES 9
Message 1 of 10
521 Views, 9 Replies
AutoCAD LT problem
Hello!
(Sorry for my English)
I have a next problem: I want to copy page in AutoCAD, but when I press "CTRL + right click + move" is nothing happenend.
How can I copy this page? (using CTRL button)
9 REPLIES 9
Message 2 of 10
user181
try hold CTRL + hold LEFT BUTTON and drag tab to copy
Message 3 of 10
pendean
.... or right-click over it, select COPY from the pop-up menu, and follow the prompts presented.
Message 4 of 10
Emmsleys
Hi @Anonymous,
Just checking up on your thread, have you tried the following suggestions made by user181 and pendean
  • try hold CTRL + hold LEFT BUTTON and drag tab to copy
  • or right-click over it, select COPY from the pop-up menu, and follow the prompts presented.
Did they help? Do you need more suggestions? Does this happen with all drawing files?
Sarah Emmsley
Technical Support Specialist
Message 5 of 10
Emmsleys
I'm following up on my previous post if you have any questions or found a workaround post back with any new updates
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Message 6 of 10
Emmsleys
I went ahead and marked the appropriate post that seemed to resolve the issue.
If you need continued help or additional suggestions post back.
Sarah Emmsley
Message 7 of 10
in reply to: user181
Doesn't work. That is the problem...
Message 8 of 10
pendean
What doesn't work?
What did you try?
Message 9 of 10
Emmsleys
Hi @Anonymous,
Thanks, for coming back to the thread!
Okay so now that we know AutoCAD LT isn't working for you as it should would you be able to provide more clarity or information on your issue?
This helps myself and others give you suggestions to try and get you back up and running. Smiley Happy
When you have a moment please provide the following...
  • What exactly the issue is?
  • File specific? AutoCAD in general?
  • Printing? Customization?
  • AutoCAD LT version?
  • Windows OS? 7,8,10?
Sarah Emmsley
Message 10 of 10
Emmsleys
Hi @Anonymous,
Just checking on your thread, hope all is well.
If you needed continued help on your thread post back in this thread and we can continue to work on the issue.
Thanks.
Sarah Emmsley
Technology Administrators
