AutoCAD LT - Multiple Layer Rename
contactZCG8K
Observer Observer
contactZCG8K
Observer
Observer
Hi all,
Is it possible to batch rename layers in Autocad LT?
eg. when collating and overlaying files name existing layers as - Grd Floor -..., 1st Floor... etc.
Or is there an easier way of doing this?
Thanks.
[ The subject line of this post has been edited for clarity by @handjonathan Original: LT Multiple Layer Rename ]
rkmcswain
FWIW - someone else was rooting around for this a few years ago, here.
R.K. McSwain     | CADpanacea | on twitter
pendean
Community Legend
Community Legend
@contactZCG8K Short answer: nothing easy/quick built-in does that but you can explore/ use wildcards in RENAME command like this if an option https://forums.autodesk.com/t5/autocad-forum/rename-multiple-layers/m-p/3772062#M187324
FWIW here is a list of Acceptable wildcards for Autocad
Character
Definition
# (Pound)
Matches any numeric digit
@ (At)
Matches any alphabetic character
. (Period)
Matches any nonalphanumeric character
* (Asterisk)
Matches any string and can be used anywhere in the search string
? (Question mark)
Matches any single character; for example, ?BC matches ABC, 3BC, and so
on
~ (Tilde)
Matches anything but the pattern; for example; ~*AB*matches all strings
that don't contain AB
Matches any one of the characters enclosed; for example, [AB]C matches
AC and BC
Matches any character not enclosed; for example, [~AB]C matches XC but
not AC
Specifies a range for a single character; for example, [A-G]C matches
AC, BC, and so on to GC, but not HC
` (Reverse quote)
Reads the next character literally; for example, `~AB matches ~AB
