AutoCAD LT - 3D linetype generation
daniel.keane576BR
daniel.keane576BR
How can I work line type generation in auto cad lt on 3d surveyed polylines to show linetypes?
There is not option to "flatten".
"LINETYPE3DPLINEOFF" is also not supported on CAD-LT
"plinegen" doesn't help as they are already drawn and changing the "Z" coordinate to "0" doesn't work!
Any help would be great!
[ The subject line of this post has been edited for clarity by @handjonathan Original: 3d Linetype generation in CAD LT ]
h_s_walker
Have you checked the linetype scale on the line?
Post a section of the relevant drawing and we can have a look at it and point you in the right direction
Howard Walker
Left Handed and Proud
daniel.keane576BR
I have checked the scale but I dont think that will work while they are in 3d. Cant figure out how to flatten them on CAD LT without re-drawing everything thats need a dotted line. An example file is attached here.
pendean
Community Legend
Community Legend
@daniel.keane576BR The LT version of AutoCAD does not 'flatten' 3D objects, sorry.
And there are no 3D AutoCAD tools in the LT version either.
***All part of the massive discount pricing that is LT: fewer abilities.****
Here is the "front" view of your content, it's not flat, 3DPolylines can be exploded into lines, the other elements in it (lines etc.) and the new lines can be manually set to Z=0 in PROPERTIES in LT but that may alter your plan view a bit
AFTER
HTH
h_s_walker
For an example I turned off all the layers apart from "Top of Slope" I then exploded the 3D polyline. I selected all the lines and changed their start and end z values to 0. I then joined them into one polyline again and changing the linetype scale then resulted in the line showing as a dashed line
Howard Walker
