AutoCAD LT crashes when I click on visibility states??
Message 1 of 24
I'm having a problem when editing a block with visibility states, that whenever I click on the visibility states button on the ribbon to bring up  the states menu AutoCAD LT freezes and crashes. Has anyone had the same problem or know a work around?
Cheers
Mark
Replies (23)
Message 2 of 24
pendean
Community Legend
Community Legend
Your LT version is...? Is it fully up to date?
Your Windows version is...?
Is the problem only with this one dynblock? Only in this file? Or it happens to all dynblocks and all visibility states in all files and with all blocks?
Message 3 of 24
LT version is 2016
Yes fully up to date
Windows 10 Pro
Happens to all dynamic blocks that have visibility states
Message 4 of 24
pendean
Community Legend
Community Legend
What is you video card? Have you tried turning off features in GRAPHICSCONFIG pop-up to see if any of that helps?
Are you setting dwg-save to something much lower than 2013dwg file format?
Is Win10 new? LT2016 is 2+years old now, it worked fine with Dynblocks back then for us (but we were in Win7).
Message 5 of 24
Video Card is Intel HD Graphics 530 with NVidia GeForce GTX 960M
Only saving down to 2013 as the other license for the company is 2014.
Win10 is new
Tried changing the graphicsconfig settings but still crashes
Message 6 of 24
pendean
Community Legend
Community Legend
I could only find one other instance of this in these forums, see if the tips offered there can help https://forums.autodesk.com/t5/autocad-forum/autocad-2014-dynamic-block-crash-with-block-editor/td-p...
Start ABOUT command and post back the exact version it lists for LT2016 please.
Message 7 of 24
Product Version: M.49.0.0 AutoCAD LT 2016
I will have a look and see if this helps
Message 8 of 24
pendean
Community Legend
Community Legend
You don't have SP1 update installed: go get it, it may help. it never installs on its own, and you never installed it.
Message 9 of 24
Downloaded the service pack SP1 but still it's still crashing
Message 10 of 24
ryan.bales
Autodesk Support
Autodesk Support
Is hardware acceleration on? If so shut if off and see if it still crashes.
Ryan Bales
Fusion 360 Product Support
Message 11 of 24
Just tried Ryan and unfortunately it still crashes.
Message 12 of 24
ryan.bales
Autodesk Support
Autodesk Support
Are you submitting any error reports?
Ryan Bales
Message 13 of 24
It doesn't allow me to. The program just freezes and I end up having to go to the task manager to shut it down. I never have an opportunity to submit an error form
Message 14 of 24
ryan.bales
Autodesk Support
Autodesk Support
And this is any drawing as in a new drawing? Or just any existing drawing with dynamic blocks?
It's possible that its related to Windows 10 and .Net.
It might be good to upload a drawing for us to test and see if we get similar results.
Ryan Bales
Message 15 of 24
It seems to be on any drawing where I have visibility states on a dynamic block.
I have attached our drawing template for you to try, there are a number of dynamic block within the template i've tried various blocks and it crashes on all of them.
On the layout page the contractor & client logos are setup as drop downs in a dynamic block. if you go to the block editor and hit visibility states in the ribbon the program freezes and won't respond.
Message 16 of 24
pendean
Community Legend
Community Legend
>>>>..On the layout page the contractor & client logos...<<<
I can change these in your file's layout without crashing at all. I did not see any errors in your file either.
Message 17 of 24
Thanks for having a look.
Changing them in the layout isn't the issue, the problem I'm having is that when I enter the block editor and click on the visibility states button on the ribbon to add some more logos etc that is when the program freezes
Message 18 of 24
ryan.bales
Autodesk Support
Autodesk Support
Are you sure the dialog box isn't simply off screen? ALT+Spacebar should allow you to move it back if so. The Visibility States button pulls up a dialog and if off screen LT will appear frozen.
Ryan Bales
Message 19 of 24
pendean
Community Legend
Community Legend
Enter the editor on your PC in this file, and post a full monitor screenshot to capture everything, and post it here (keep it full size please).
Do you know how to use the free screen capture tool in Windows? here is quick review to post the image, not to dump it into an MSWord document or anything else https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
Message 20 of 24
Ryan it seems that the dialogue box could be off screen as I can move the mouse around etc but pressing alt+spacebar brings up a menu with options to move/size or close but i've tried to move the dialogue box if it was off screen but with no success.
Pendean.
Snip shots attached
