AutoCAD LT Forum
AutoCAD LT 2021: "LISP command is not available" when pasting image as Image Entity
3 REPLIES 3
huyvo91
742 Views, 3 Replies
I used to have no issue pastespec-ing an image as Image Entity back in AutoCAD 2007 so that I can imageadjust it to my liking but with the LT 2021 version, I can only paste an image as an OLE object and when I try to paste it as an Image Entity, the error "LISP command is not available" appears and nothing would happen. Does anyone know how to "fix" this?
Labels (2)
3 REPLIES 3
Patchy
in reply to: huyvo91
No LISP for LT because it can't run .lsp
pendean
"bitmap" is the only option you can use in LT, even though the other is there, it is not an option.
huyvo91
in reply to: Patchy
I see... it's a shame since the LT version meets 99% of my needs on the daily basis. Thank you for the info.
Forma Design Contest
Technology Administrators
