You need to turn off the layers other than the layer which is isolated.
To do that you need to type in the command "LAYISO" and then select "SETTINGS" from the command line.
Now select "OFF" to turn off the layers that are not isolated.
And again select "OFF" to turn off the layer in paperspace.
Now the LAYISO would only isolate the selected layers, and the other layers would be turned off.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
