AutoCAD LT 2020 - Unisolate command does not work
fegbue3FE5G
Observer Observer
Message 1 of 9
fegbue3FE5G
Observer
Observer
I used the isolate command to isolate a couple of layers. When I try to unisolate the rest of the layers all at once, they remain locked and the unisolate command does not work. Is there a fix for this?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (8)
Message 2 of 9
steven-g
Are you using 'isolate' (only works on objects, not layers) or 'layiso' which does work with layers, the respective commands then are 'unisolate' (only works for previously isolated objects), or 'layuniso' which works for layers.
The layiso command locks other layers, the layuniso only unlocks the layers that you locked using layiso it won't affect the settings of layers locked using the layermanager icons.
If you still have problems then describe the steps (and the actual commands you are using)
Message 3 of 9
vinodkl
You need to turn off the layers other than the layer which is isolated.
To do that you need to type in the command "LAYISO" and then select "SETTINGS" from the command line.
Now select "OFF" to turn off the layers that are not isolated.
And again select "OFF" to turn off the layer in paperspace.
Now the LAYISO would only isolate the selected layers, and the other layers would be turned off.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 4 of 9
fegbue3FE5G
Observer
Observer
Thank you very much Steven, that was very helpful. I'm all set. Much appreciated.
Message 5 of 9
How is this the solution?.. this is an on going problem!
Message 6 of 9
steven-g
It did appear to save the OP's question. If you are having problems then the issue is probably something else. It might be an idea to start a new thread and describe what is different about your situation that is different.
Message 7 of 9
dvicarioXT
@Anonymous, I've discovered that if you use the ACA ribbon, the unisolate icon is mapped with the wrong command. So they've mapped the Isolate one correctly with the LAYISO command:
And then the Unisolate one with UNISOLATE instead of the correct LAYUNISO:
I've manually changed it in the CUI, and now it works.
Hope that helps
Message 8 of 9
haines.300
Can you explain how you did this? I have been having the same problem intermittently.
Message 9 of 9
cadffm
He wrote about another, an offtopic issue in an offtopic software
and you are using an Architecture version with this bug ?
(the Icon starts another command, so you oress&release the button, pressed [F2] and the started command is not "_LAYUNISO")
If so, the command to edit your .cuix files is: CUI
Ribbon, Panels, LAYER - ACA, row1
Sebastian
