AutoCAD LT 2019 citrix compatible
I'm looking to determine what version of citrix AutoCAD LT 2019 is compatible with.
Looking at citrix chart and system requirements for the application requirements i'm not seeing any specific to my version.
Citrix  (xen app / xen desktop 7.6)
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
Sys requirements - only states local PC requirements
(https://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/Sys...)
I need to deploy the application using Citrix 7.15
Any help would be appericated
john.vellek
Hi @Anonymous,
From my understanding, 2019 products will match those listed in that article for the 2018 products. I know that this documentation is actively being updated and I apologize that it has not yet happened.  If you have any additional specific questions on AutoCAD LT 2019 and the Citrix environment, please add them here and I will research to find you some answers.
John Vellek
I specifically need to know if AutoCAD LT 2019 is compatible with Citrix 7.15.  can you confirm if this is the case?
john.vellek
HI @Anonymous,
I looked at the System Requirements for AutoCAD LT 2019 and there is no Network section. My understanding is that even for full AutoCAD license, it needs a special network license to run over Citrix. Since this section is missing from the LT requirements, I have been informed that this product is not a supported or certified one in that environment.
John Vellek
Thank you - consider this resolved
