Autocad LT 2017 script errors when loading drawings from network drive
Message 1 of 12
Hello
Further to other posters who have had AutoCAD 2017 present them with two script errors when loading, I'm also getting this, but in a different circumstance.
If I load the drawing off a local disk it works fine, if I load it off a mapped network drive then it hangs on the license check, then presents the two script errors as attached. Whatever is chosen from here AutoCAD hangs. AutoCAD also creates a folder in the same location as the network drawing with three javascript files in (as referred to in the script error box).
This has all been installed onto a fresh Windows 10 Pro PC. I've tried removing AV/AutoCAD and re-installing. I've also tried the other remedies for similar issues to no avail. Can anyone shed any light on this?
I have other computers running AutoCAD 2017 without issue so this isn't a general problem...
rob
Replies (11)
Message 2 of 12
Really keen to hear back on this, does anyone have any thoughts?    All suggestions tried from other threads where people are having the same issue
I'd like to raise a support ticket with Autodesk - can anyone point me to official support?
Message 3 of 12
pendean
Community Legend
Community Legend
Autodesk Support is explained here https://knowledge.autodesk.com/customer-service/account-management/subscription-management/support-o...
Direct support is through your subscription page: log in here https://manage.autodesk.com/cep/#products-services, ensure you are on the Management page, fist the SUPPORT pulldown menu at the top right of the page, select VIEW MY SUPPORT CASES, then select an option and ask. Ensure you assign a priority to your request (not everything is an emergency).
Feedback can also be sent in on the online Product Feedback form: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Message 4 of 12
rkmcswain
cfadministrator wrote:
.....can anyone point me to official support?
Message 5 of 12
Emmsleys
I went ahead and escalated your thread to a case for you.
For future issues like this use the suggestions made in the previous post's or post back in the forums. I'm happy to help.
Sarah Emmsley
Technical Support Specialist
Message 6 of 12
Emmsleys
Also if time allows please select Accept as Solution if  any post in this thread resolves your issue or answered your question.
Thanks.
Sarah Emmsley
Message 7 of 12
Emmsleys
To add,
Have you tried a
Clean uninstall of AutoCAD?
  • Along with
    • Clear temp folder
    • reset to defaults
  • Downloading AutoCAD LT 2017 from the virtual agent
  • Full admin rights to AutoCAD
  • Full admin rights to network folders that you are accessing your files from (if you are working off of a network)
Sarah Emmsley
Message 8 of 12
Emmsleys
Have you tried to mimic the OS and AutoCAD LT settings of your co-workers who are not having this issue?
What has changed on your system that it is now having this issue?
Have you applied all updates?
Sarah Emmsley
Message 9 of 12
thanks, will try suggestions and revert
Message 10 of 12
Removed AutoCAD, removed all folders/reg entries and re-installed - same problem re-occurred....
How long before support will get in touch?
Message 11 of 12
rkmcswain
What type of support plan do you have?
Autodesk is not going to seek you out unless you've opened a support case with them, in which case you should be following up there, not here.
Message 12 of 12
pendean
Community Legend
Community Legend
