AutoCad LT 2017 …. Computer requirement help
spag1
spag1
Hoping someone experienced with Autocad LT 2017 and computer knowledge can offer their expertise on whether this computer that Im considering purchasing, would be compatible with Autocad LT 2017.  Would greatly appreciate any feedback. Ty
The ThinkCentre M70T Tower is designed to help you get what you need to be done, quickly and efficiently.
Power-packed and business-ready, the ThinkCentre M Series is the perfect choice for progressive IT managers looking for high-performance, reliable, and secure desktops. Easy to set up, deploy, and manage in any office environment. They boast the latest processing, memory, and storage technology, and have a number of large storage capacity options.
Brand / Model: Lenovo ThinkCentre M70T
Form Factor: Tower / Desktop
Operating System: Windows 10 Pro 64-bit
Processor: 8-Core Intel i7-10700
CPU Frequency: 2.9 GHz - 4.8 GHz
Cache: 16MB
RAM Slots: 4x
RAM Speed: 3200MHz
Memory: 16GB
Max Supported RAM: 32GB DDR4
Storage: 512GB SSD + 1TB HDD BACKUP
Storage Slots: 1x 3.5" HDD
Graphics: Intel UHD 630
Video Ports: 2x DisplayPort (4K), 1x HDMI
Front USB Ports: 2x USB 3.2 Gen 1, 2x USB 3.2 Gen 2, 1x USB Type-C Gen 1
Back USB Ports: 4x USB 2.0
Ethernet: Gigabyte 10/100/1000, RJ-45
Wi-Fi: 802.11ac
Bluetooth: 4.2
Audio: Built-in Speaker
Audio Ports: Microphone, Headphone Jack
Power Supply: 260 Watts
Contents: USB Keyboard / Mouse
pendean
Community Legend
Community Legend
Old LT2017 does not tax desktop/laptop computers much: the only challenges you might encounter is going to be running it smoothly in Windows11, and whether you can find and install the required 2017.1.1 update or not to avoid any other potential issues
https://up.autodesk.com/2017/ACD/AutoCAD_2017.1.1_Update_Readme_Enu.html?_ga=2.10177788.870111934.16...
LT2017 system requirements:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
HTH
spag1
Thank you Pendean for your response!  This computer does come with Operating System: Windows 10 Pro 64-bit since the requirements lists W10 as being the highest to use. From my research updates for 2017 autocad run til mid 2025.  Thank you for your feedback!
paullimapa
May want to consider the fact that though you can successfully install older versions of AutoCAD like 2017 on Windows 10 Pro, Autodesk may no longer support activation of old versions that far back.
Paul Li
IT Specialist
@The Office
