PLEASE HELP.
due to problems i had to re-install my software and was able to install SP 1.
however i cannot download 2017.1.1. also not through the desktop app.
the desktop app shows update 2017.1.2 , but this cannot be installed due to the absence of 2017.1.1
PLEASE HELP
Solved by cadffm. Go to Solution.
Do you have a license for LT2017?
cool
From where is the LT Update 2017.1.1 ? I need it too
And back to the topic: I don't understand your Problem!?
2017.1.2 is just a Hotfix for HP Drivers, no installation needed - just extract the files
and replace the original files (afters backup) with them, that's all.
Sebastian
yes i have a licence
it is the fall update which comes with massive improvements. such as txt2mtxt .
@pbijsterveld wrote:
PLEASE HELP.
PLEASE HELP
No reference on the web to a 2017.1.1, sorry, but you might as well get and install 2017.1 now https://www.google.com/search?q=AutoCAD+LT+2017+1.1+update
As for 2017.1.2... https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoc...
Yes, but you asked about it because of 2017.1.2 and I explained it isn't possible to have
problems to install it, because there is no file to install something - so you don't need 2017.1.1 for this.
(How to get 2017.1.1 : Turn on you antvirus and antimalware and all other things and search for AutoCAD_LT_2017.1.1_Update_64bit.exe )
Sebastian
@pendean schrieb:
Noreference on the web to a 2017.1.1,
https://up.autodesk.com/2017/ACD/AutoCAD_2017.1.1_Update_Readme_Enu.html
http://up.autodesk.com/2017/ACDLT/AutoCAD_LT_2017.1.1_Update_64bit.exe
Sebastian
