AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT 2016
7 REPLIES 7
Message 1 of 8
358 Views, 7 Replies
AutoCAD LT 2016
My screen constantly flickers causes me to mistype quite a bit. This happens with every application, IE, Crome, Word document, etc.,any suggestions
7 REPLIES 7
Message 2 of 8
pendean
If it happens with all applications, you need to take your PC to a repair shop now. No one here can help you.
If it only happens with LT2016... Turn off LINESMOOTHING and LINEFADING in LT2016.
If it still flickers, start GRAPHICSCONFIG command and disable (or enable) other features and see if these help.
Message 3 of 8
in reply to: pendean
It happens with all applications only after I've installed 2016. When I
uninstall everything works fine.
Jamal Creecy
ES&H Specialist
Rockwell Collins
3200 East Renner Rd.
Richardson, TX 75082-2402
(972) 705-6102
Message 4 of 8
pendean
Did you get a chance to try my recommendation, second paragraph in my first reply? Three things to try.
Message 5 of 8
I've just had exactly the same problem, in fact I've just posted a new topic about this highlighting a youtube video.  Do you ever find a solution to this? Autodesk seem to be unaware of this problem.
All the best,
Andy
Message 6 of 8
pendean
"LT2016... Turn off LINESMOOTHING and LINEFADING in LT2016.
If it still flickers, start GRAPHICSCONFIG command and disable (or enable) other features and see if these help."
Screen flickering means your video card doesn't work in AutoCAD: Autodesk posts drivers for video cards it thinks are worthy of the attention here, all others are just not currently tested or supported http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
Message 7 of 8
I tried the steps of turning off LINESMOOTHING AND LINEFADING. I also
turned off the graphicConfig...I will try the link you provided..
Jamal Creecy
ES&H Specialist
Rockwell Collins
(972) 705-6102
Message 8 of 8
pendean
Technology Administrators
