AutoCAD LT Forum
AutoCAD LT 2016 - Viewport Scale - Showing Inches not MM - help?
5 REPLIES 5
13984 Views, 5 Replies
Hi All
I'm new to LT 2016; having used 2007 for some time.
I'm trying to create viewports in paperspace and then scale them. This used to be relatively simple in a viewports tab which I had pinned to my personal template...
I've worked out that viewports are now created using the layout tab and then 'layout viewports'. To scale, I have discovered that this is highlighted in the properties to the left.
However, when I choose the dropdown menu in properties, it only gives me the option of inches and not mm. Can someone help?
Screenshot attached.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Viewport Scale - Showing Inches not MM - help? ]
5 REPLIES 5
hwalker
Welcome to the Forums
What units is the drawing set as?
Also you can reset the scales by typing -SCALELISTEDIT(Note the hyphen at the beginning of the command) at the command line and then telling it to RESET
Howard Walker
Left Handed and Proud
in reply to: hwalker
the drawing is set as decimal/mm...
but when i select the 'scale viewport' button...
...i only get a list of scales in inches (along with a few of my own failed attempts at custom scales at the top, which remain at 100% scale)
I am able to succesfully scale the viewport using zoom; 1/500xp, but when i try to add my own custom scales on this list, I cant seem to get anything other than 100% scale.
pendean
Share your DWG file if using -DWGUNITS command (there is a dash in the name) to properly set your file's drafting units is not working.
Try this:
1) Custom...
2) Add...
3) Type a name (1:2000)
4) Set the scale:   Paper units = 1 Drawing units = 2000
5) ok.
It works !)
jos6VQNY
This is the solution, You reset it to metric
Technology Administrators
