AutoCAD LT 2016 Start screen will not fill the entire screen
ronen
Message 1 of 37
ronen
Just installed AutoCAD LT 2016, and the start sreen fills only 2/3 of upper left screen.  Any idea how to fix this?
Accepted solutions (3)
Replies (36)
Message 2 of 37
pendean
Community Legend
Community Legend
No sure what you mean exactly: can you better clarify?
Message 3 of 37
ronen
Yes, when I start the program, the welcome screen that features recent files
as well as a choice of actions, does not show on the entire screen (see
attached). And also does not respond well to mouse clicks.
Ronen Gilat
423-307-3983
www.gilat.org
Please consider the environment before printing this e-mail.
Message 4 of 37
ronen
Message 5 of 37
pendean
Community Legend
Community Legend
Are you running LT2016 on a tablet or laptop with a hi-res display?
And did you change the display settings? Windows OS is what?
See the double at the bottom? It appears your video card is chocking or your AutoCAD is locked up too.
Message 6 of 37
ronen
laptop with 1920 X 1080 display. No, i did not touch the computer. and it was fine in the LT2015 version.  Runing windows 8.1
the program is working just fine... it just the welcome screen.
Message 7 of 37
pendean
Community Legend
Community Legend
OK, that matches my monitor settings so that's not it: does the problem fix itself if you maximize the AutoCAD screen? I notice it's not in your screenshot.
Have you restarted your PC since the 2016 install? See below, I don't seem to have that issue (not maximized).
Message 8 of 37
ronen
No, the problem does not fix it self when maximize, and yes, I did restarted the computer since the installation.  No luck...
Message 9 of 37
ronen
Well, this is what happen when i play with the window size.  i have tried the same when a drawing is open, and everything is fine.
Message 10 of 37
pendean
Community Legend
Community Legend
OK, about the only time I see that is if AutoCAD and a video card do not get along. May I ask what is your Vid Card and your PC specs?
Message 11 of 37
ronen
Sorry for the delay.  I'm using AMD Radeon HD 8700M, and also Intel HD Graphics 4000.  It may be that those two don't play nice with one another.
Computer: Samsung Series 7 Chronos, Intel Core I7 2.40Ghz, 8.0 GB memory.
Message 12 of 37
pendean
Community Legend
Community Legend
I've read oter users with dual video cards having to turn one off in the system BIOS or being able to assign it for special use in order for such issues going away.
Bottom of this link offers two tips, one a youtube video and the other a lower compatibility mode solution. I'm sure there are others if you want to explore in your favorite search engine http://www.tomshardware.com/forum/372529-33-help-disable-intels-hd4000-enable-radeon-7670m
Message 13 of 37
ronen
thanks, highly appreciated.  I'll keep you updated.
Message 14 of 37
bryce.thelin
This does look like AutoCAD could be using the wrong video card. Were you able to set AutoCAD to use the AMD card or disable the Intel card in your bios, and did that help?
Bryce Thelin
AutoCAD Product Support
Message 15 of 37
ronen
No, I was not successful. The AMD card already had the LT2016 as a "high performance" and I was not able to fix this. I do appreciate your concern and follow up. One day I'll have time to try and resolve this...
Thanks again.
Message 16 of 37
bryce.thelin
Try this:
  1. Click the Start menu and type "display" in the search field or type it at the desktop.
  2. Select "Smaller - 100%" and then click Apply.
  3. Log out and back in to Windows or reboot the computer.
Let me know if this fixes the problem.
Bryce Thelin
Message 17 of 37
bryce.thelin
Hi Ronen,
Did setting your text size in Windows to 100% fix the problem? I had a case with this with another customer and that took care of it for him.
Bryce Thelin
Message 18 of 37
ronen
Thanks for following up on this, however, I am out of the country until the middle of the month without my computer. Upon getting back I will try this and update you.
Thanks again.
Message 19 of 37
alegarvaz
Community Visitor
Community Visitor
I had the exact same problem, and this solved it for me!
Message 20 of 37
I'm having the exact same problem. The help screens do the same thing.
Acer laptop with Intel HD Graphics 4000.
