need to move from old computer to new
Solved by Emmsleys. Go to Solution.
Solved by pendean. Go to Solution.
Hello @Anonymous,
Welcome to the Autodesk Community!
To add to the thread here are the system requirements for AutoCAD LT 2012;
For 32-Bit AutoCAD LT 2012
Or
For 64-Bit AutoCAD LT 2012
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
HI @ USHouse8857,
I'm following up on my previous post. If you have any questions about my post let me know.
If you still need suggestions or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
