Since the beginning of this week when attempting to open AutoCAD LT 2012 I receive the following error message and am unable to open the program:
FATAL ERROR: Unhandled e06d7363h Exception at fda1cacdh
I've tried the program repair and the program reinstall with no change. I installed Service Pack 1 but it had no effect. I guess the next option is the Windows System Restore, but I'd rather not if it's not necessary. I have Windows 7. Any ideas? Thanks in advance.
Try the Restore to a week or so ago. Can't hurt.
Suddenly not working can be a Registry Cleaner, Windows Update, or new program perhaps.
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I just bought autolt 2012 its activvated I keep getting this fatal error unhandled access violation Ive tried reinstals ect.
this is brand new Im not paying for support until its running WHERE DO YOU GO IN THIS COMPANY FOR SUPPORT TO GET STARTED!
Welcome to the Autodesk Forums!
Up and Ready Support is where to begin; though being a two year old program that too may be problematic.
Where did you purchase the software from?
Support Offering: (click the tabs for options)
http://usa.autodesk.com/support-offerings/basic/
Licensing and license tranfer tips and help are at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
Autodesk support is now on Twitter 24/5 (@autodeskhelp): https://twitter.com/AutodeskHelp
With a blog: http://blog.autodeskhelp.com/
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/support-offerings/up-and-ready/
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/support-offerings/per-incident/
If you are on subscription, visit your Autodesk Subscription Page for direct Autodesk Help:
http://www.autodesk.com/subscriptionlogin
Contact a Reseller for support (not free):
http://www.autodesk.com/reseller
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240617
Your issue could be .NET or C++ installs on your system.
Can you post the error message?
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
The above is a thorough approach. Uninstalling all instances of .NET and C++ and then reinstalling these may help.
A third option that may be the best place to start:
Autodesk Recommended Clean Install Procedure:
Uninstall the .NEt and C++ then perform a hard reboot.
Log in as an Administrator to your System and then install CAD and the needed .NET and C++.
Open and authorize CAD as an Administrator.
