I wonder if AutoCAD LT 2007 would work with Windows 10 x64 OS. Now is working on a W7 x64 with no issues.
Would you please advice on this?
Solved by pendean. Go to Solution.
Solved by hwalker. Go to Solution.
No. LT 2007 is not supported on Windows 10 software.
You'll need to upgrade or as @pendean has pointed out before https://longbowsoftware.com/ might be able to help
Howard Walker
You have a much bigger hurdle: Autodesk killed off reauthorizing of 2010 and older software (that includes LT2007) as of August 31 2019 https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
Sorry, you missed the deadline. There is nothing you can do about it today. There is no third party fix either.
Hang on to your old PC for as long as it will last.
Hi @Anonymous ,
you received some valuable information from @pendean and @hwalker, also I guess it might not be the answer you wanted or expected but the resources both linked are the information that gives you the current state of things.
For the new computer / OS configuration you might want to give a try with the AutoCAD LT trial to see if it´s valuable for you to consider using the newer version.
Feel free to mark both posts above as solutions so other community members who are also trying to find this information can do so more easily.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Tarek Khodr
