Haven't used AutoCad for quite a while but when copying an item using ORTHO mode and coordinates, e.g. 0,-50 the copy ends up to the left and below the original. Even using 0,50 copy ends up in same area. Can anyone please advise. Is it to do with UCS, WCS, etc.?
Solved by pendean. Go to Solution.
I've somehow altered the scale of objects in my drawing inadvertantly. Can some please advise how to change the scale. I've referred to the 'Help' source but without success.
The object in my drawing now measures incorrectly, I must have somehow changed the scale of my original object/drawing. Does this clarify my query?
When I first drew the 'object', I used DIST to confirm the sizes and added the dimensions to the drawing. Now, when I open up the drawing, the dimensions shown are totally different! So, I'm assuming that somehow I've changed the drawing scale??
INSUNITS will resize blocks on INSERT if set incorrectly as well.
Or you imported the incorrect object.
You can use SCALE command to start fixing everything too.
You somehow triggered a 2.5 scale reduction: I can;t tell what it is you did or are doing from way over here sadly.
