AutoCAD LT Forum
AutoCAD autosave is faulty
1 REPLY 1
sophiem8QVBV
173 Views, 1 Reply
Hi
When working on a dwg file, autosaves arent happening at all. All boxes are ticked on the 'open and save' options window. (log file, automatic save, backup with each save - everything), and nothing is happening at all.
I've even set the SAVETIME to 1, and it does an initial save, and then nothing.
Also, when I restart, it appears to wipe the temp file of all ac$ and sv$ files.
I just crashed, and there was nothing to salvage.
Any help would be greatly appreciated. Thanks!
1 REPLY 1
pendean
in reply to: sophiem8QVBV
Start here (long list) https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-ensure-auto...
Other things to try to recover from a crash:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Understanding-Auto...
BTW, SV$ "autosave" files are never EVER preserved if you successfully save and close the file you are using as a general rule.
Forma Design Contest
Technology Administrators
