AutoCAD LT Forum
AUTOCAD AND TRUEVIEW
1 REPLY 1
409 Views, 1 Reply
I DOWNLOADED TRUEVIEW SO I CAN CONVERT MY DRAWINGS INTO OLDER FORMATS BUT NOW EVERY TIME I OPEN A DRAWING IT AUTOMATICALLY WILL OPEN UNDER TRUEVIEW INSTEAD OF AUTOCAD. HOW CAN I CHANGE THE SETTINGS SO CAD IS MY DEFAULT PROGRAM?
1 REPLY 1
pendean
Start AutoCAD: use OPEN command to open a file. Save the fil, close AutoCAD.
Problem should go away until the next time you open DWGTRUEVIEW: it's a limitation of WIndows, it only assigns DWG to the last program that helps itself to it.
Forma Design Contest
Technology Administrators
