I am just starting to learn AutoCAD and I would like to know what are the most vital PC requirements. I have seen the system requirements and I am purchasing a new pc and would like to keep my costs down so I want to be able to get the system requirements to properly run AutoCAD but don't want to get the top end of a computer system if I don't need it. Thank you in advance for any knowledge and information regarding this that you can provide.
Solved by pendean. Go to Solution.
Basically, any PC running Windows will run AutoCAD LT 2020. Will it run good if it's a $450 computer? Probably not. Go with the minimum specs published by Autodesk as a bare minimum for decent performance. If you have a choice, spend your money on clock speed for the processor (instead of # of cores), then a fast hard drive, then RAM, then video.
That is the quick and dirty version. Ask if you have more questions.
@Anonymous said: "I have seen the system requirements"
