I am recently experiencing sluggish performance with 2019 LT. I run Windows 10 on a fairly new computer. I am no computer expert, but I think my system is well beyond the minimum requirements to run LT.
Intel i5 processor
12 GB ram
64 bit
I have tried the optimization tips provided by Autodesk, but have not had much success. One tip I have not been able to understand states
I have been unable to locate this command. Can someone point me in the right direction? Thanks!
Thanks for the help. As you expected, that solution was a long-shot and did not seem to help. However, things are running a little better now. I employed as many of the Optimization Tips as I could. I think the one that made the most difference was setting my graphics to "basic." It is still a bit jumpy, especially when using a hatch command. My previous versions operated much more smoothly on a much older and less capable computer.
Regarding your suggestion of resetting 2019 to its defaults, what functions are effected? I am always nervous to try the "restore default" route. Thanks again.
AutoCAD 2019LT is still jumpy with certain commands, particularly hatch, stretch, and measure (area) among others. As I mentioned earlier, I am running a new computer with - I think - more than adequate hardware (Intel I5 processor, 12 GB ram, and 64 bit architecture). Are there other hardware issues that could impact the speed and response of the program, like the graphics card, etc?
