AutoCAD LT Forum
Auto Cad LT
1 REPLY 1
358 Views, 1 Reply
Auto Cad LT
Argh. I downloaded and copied the autocad.exe associated with the AutoCAD 2017 SP 1 Windows 10 F Key Hotfix 64 bit because my F8 ortho key was freezing each time it used it. Swapping out the .exe file messed things up and now every time try and load autocad it aborts with and fatal error message. How do fix this and get back up and running?
Error message "Unhandled Access Violation Reading 0x0001 Exception @ f15db3e0h"
Please help,
Kevin
1 REPLY 1
pendean
You need to remove and reinstall LT2017 with SP1.
Then simply turn off TEMPOVERRIDES variable to stop F8 from locking up the program like the alternate fix at the bottom of this page notes https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Functi...
Forma Design Contest
Technology Administrators
