AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Attribute keeps returning to default
2 REPLIES 2
380 Views, 2 Replies
I am creating a block which is relatively simple, it contains the outline of exterior and interior walls and services within the block so we can plot our drainage and Attributes to show the coordinates of the block.
When I paste the block into the site layout drawing, 2 out of 4 attributes go back to default ####################
I selected the block and opened it within block editor to change the default attributes to object centre to show X,Y,
When I back out of block editor it goes back to default.
Can anyone advise?
Rhys
2 REPLIES 2
jayhar
First you purge your cad file, then past....
in cad file same block name cannot paste.
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
pendean
Post your DWG file with the block with the problem, let's all have a look.
Forma Design Contest
Technology Administrators
