AutoCAD LT Forum
Aligning 2 drawings
1 REPLY 1
otto.vonknorring
524 Views, 1 Reply
Aligning 2 drawings
I have two drawings and want to align one with the other so that drawing A gets the sam position (cordinates) as B.
A have no real world cordinates and B does. The drawings are of a firestation but of difrent floors.
What i have done.
First I used scale on the one i want to align (mm to meter) and then copy paste it too the drawing with the right alignment . After that i aligned them but then they are right on top of each other and i dont know how to separate them.
There must be a diffrent way of doing what i want?
Any help is much apricated
1 REPLY 1
steven-g
in reply to: otto.vonknorring
Without getting to complicated, imeadiately after you have used the align command and the objects change position and are on top of each other, then start the select command and when it asks you to select items just enter "p" (for previous) at the command line and press enter twice, this will highlight all the stuff that just moved and you can use the move command to place it where you need.
Forma Design Contest
Technology Administrators
