Add Prefix to existing text in AutoCAD LT
rravgeotec
rravgeotec
Hello Everyone,
I not familiar with Macro and Lisp and tried to search a lot of macros to add prefix and suffix in the existing text. But, not get much success. Please help to give me a macro to add a prefix in the existing text.
regards
Ravi
Accepted solutions (4)
steven-g
That isn't going to be an option in LT, first, there is no Lisp in LT so that option doesn't exist. The next problem is that Macros don't work with any command that opens a dialogue box and the 'mtedit' command opens the mtext editor which as far as macros go is a dialogue box. But if all the text items are the same then the 'find/replace' command will work, no need for a macro. If the text items all start with different values then I'm afraid it is down to manual editing one by one.
cadffm
That's because of: There is no command to do that.
(and Lisp is not available in LT Version?
Sebastian
rravgeotec
thank you for the reply. just last question!!
I do not want to open any editor. just want to add "XXX" (could be any three alphabets) in the existing coordinate (number). i.e.
43.20 --> XXX43.20
56.52 --> 56.52XXX
"XXX" will be in macro. no problem, if it's work only for "TEXT".
I google and found we have a macro to add prefix with increment number.
cadffm
Sebastian
pendean
Community Legend
Community Legend
Explore here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Not perfect but at least it will get you part of the way there
rravgeotec
Thanks a ton, pendean !!
