I accidentally removed the "Polar Stretch" action from the block creation palette and I can't restore it.
Can you help me add this command to the palette?
This opens a dialogue box as shown, Rename the action (this is what you will see in the 'Actions' list), it would be a good idea to also give a correct description. And then click in the 'Type' box to highlight the drop-down arrow and you can then select the type of action you had deleted. Press OK to exit the dialogue and your new action should now be working, (you can left-click and hold and drag the action to reposition it in the list if you want).
