After many years away from a true AutoCAD product, I am a bit perplexed by how to find the user manaul or index.
For example, I am learning more about dynamic blocks. I am sure that somehwere there has to be a chapter about dynamic blocks that goes over all the features and commands associated with them.
Note that I am not seeking a quick getting started guide. I also know I can do a search of the online help, but this typically gives you a brief paragraph, and then a few links to related topics. But, attemping to navigate those links does not give a cohesive picture of the feature.
How do I get to the user manual?
Solved by Charles_Shade. Go to Solution.
Solved by hwalker. Go to Solution.
Welcome to the forums
It's called Autodesk Exchange now.
If you click on the ? and then choose help. Autodesk Exchange will pop up. You can then search for Dynamic block help.
Also for Dynamic block help I would suggest you go to the Dynamic Block Forums you will get lots of help there.
Howard Walker
Thank you both for the reply. The "Autodesk Exchange" was in fact where I was looking for help before. It just wasn't there in the sort of depth that I needed. I come from the v10 days, when the stack of user manuals was over 4" thick. I think I was just expecting something different than what is typical now days.
Charles, thank you very much for those PDF's from Autodesk University. Those were what I was looking for, although I see they were from 2006 and 2007. So, I imagine they are somewhat outdated. Is this something that I can find on Autodesk's web site for 2014?
The download area for Acad LT 2014 only has tutorials from 2011 at the latest, and there are the getting started guides. It seems that all the in-depth documentation must be purchased.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
For a while the on-line manual was equivalent to what the printed manuals used to be. But, so far, for everything I have looked up in the on-line manual, it has not been useful. It seems that Autodesk still does create those manuals, but they sell them separately, rather than including them with the program.
The failure to include a useful manual with the software is more than a little irritating to me. It may be enough to stear me away from the product.
