Just downloaded 2018 and the buttons are thick and blurry, the drawing is fine and I've checked Resize ribbon icons to standard sizes but they are still out of focus. I migrated out of 2017 (which migrated out of 2015), and previous versions are lovely and crsip.
There's bound to be a simple solution buried in options somewhere?
Thanks to anyone watching.
I am baffled why they have got this so wrong! ACAD 2017 works perfect, 2018 is a blurry mess of a program.
Why hasn't anyone at Autodesk picked up on this and solved it??
Mitmorris, this is also a problem on 4K monitors, I have one and the icons are blurry!
I thought it only happened on 4k monitors, what resolution are you running at?
Well Im running a 4k Iiyama monitor at 3840x2160 and the icons are too blurry to use. Hurts my eyes after about 5 mins of use. 2018 is useless!
The 'dark' scheme is darker in older versions than 2018: with the slight increase is sizing I can see how it can be seen as blurry.
This issue still exists, is anyone at Autodesk aware that this is a problem??
Look at the attached screenshot, the inner window is v2016, perfect quality 4k icons. the outer window is 2018, with garbage blurry (slightly oversized) icons. After a while my eyes actually hurt whilst using the 2018 interface so I have to revert to 2016/17 again.
Deliberate design change?? For real?
Someone's head needs to be on the block for this one!
Problem is I've recently switched from maintenance plan to the subscription so I presume at some point I will lose access to 16/17 and be stuck with 18.
Really hope they take their head out the sand on this one and get it sorted, if not for 2018 then for 2019!!
