Had an issue with one particular dwg (so far) that created a fatal error. Forwarded automatic reply to AD and was sent back a link to update to AutoCAD LT 2018.1. Selecting it brings up https://knowledge.autodesk.com/support/autocad/learn-explore/caas/blog/blogs.autodesk.com/autocad/au...
then selecting Autodesk Desktop App brings up https://blogs.autodesk.com/autocad/autocad-2017-autodesk-desktop-app/?_ga=2.84868505.1650920111.1580...
Where can the suggested 2018 update be found?
Solved by cjshaw14. Go to Solution.
Solved by cadffm. Go to Solution.
Have not had a chance to try as person has been out, if it doesn't work will do the old fashion way and edit manually.
thanks
