2017 SP1 download for AutoCAD Lt
Message 1 of 9
I cannot install SP1.  It says product could not be installed because the expected Autodesk product could not be located on your computer.  When I click on the detalis of the exe it shows the file location in my downloads folder not my program folder.  How do I fix this so I can install the service pak.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Are you an owner of the REVIT LT Suite that also includes LT2017?
Your Windows version is...?
Which update did you download?
Message 3 of 9
Emmsleys
Are you running other applications of Autodesk or a suite?
Sarah Emmsley
Technical Support Specialist
Message 4 of 9
I have Windows 10 Home 64 Bit
AutoCADLT2017
I downloaded 2017SP1. The supported program list does list AutoCAD LT.
The problem is when I go to install, it is looking for the program in my
downloads file not the programs file folder.
George Tavares
HEI Security
1 Washington Street
Pelham, NH 03076
Cell: 603.396.2999
Message 5 of 9
pendean
Community Legend
Community Legend
You downloaded 2017SP1: that's for AutoCAD 2017.
LT 2017 download is here https://knowledge.autodesk.com/support/autocad-lt/downloads
You got distracted by a typo: always use the correct source for the correct software and you can avoid these human errors.
Message 6 of 9
I can install, the source is not the issue. The issue is where it is
looking for the program. I cannot change that. It does not allow you to.
George Tavares
HEI Security
1 Washington Street
Pelham, NH 03076
Cell: 603.396.2999
Message 7 of 9
pendean
Community Legend
Community Legend
Windows tells it where to look. Nothing else.
2017sp1 is the wrong download. You need the LT2017sp1 download: this comes up often.
And it works just fine if LT2017 was run and closed prior to the install of SP1.
Try again, start with the correct file and source.
Message 8 of 9
Thank You!!  That worked.
I was just following the original instructions that pointed me to the other DL that says it is for my version.
George
Message 9 of 9
Emmsleys
Thanks for posting back what worked for you!
Sarah Emmsley
