Hi. I have been using AutoCAD 2004 for many years and also started leasing AutoCAD Lt. a year ago. I'm really having problems getting used to the 2017 version. Is there not an area toolbar on the 2017 version? Any help would be much appreciated. Thanks, Allen
Solved by john.vellek. Go to Solution.
Hi @billnallen,
I bet that jumping to 2017 from 2004 has been a pretty major change. As others in thread have so kindly pointed out, the Area command is found in the Utilities panel on the Home Ribbon.
Also, as Dean pointed out, You can find Area in Inquiry which is under the Tools pulldown menu.
If you don't see the pull-down menus you can drop down this arrow and select "Show Menu Bar"
