Converting Layers
j_seph
Converting Layers
j_seph
We get cad files from another company which of course use their own layer standards. I am trying to find a way that I can convert their layers,colors,linetypes to our standards w/o having to do each one individually.
Thanks in Advance
Replies (11)
I do not have experience with this but I think the standars manager is what
you are looking for.
Joe
wrote in message news:5461341@discussion.autodesk.com...
individually.
Thanks in Advance
on further review, I may have jumped the gun.
If they give you the same layer all the time you could create a script file
using the RENAME command and jus run it on there files when they come in.
Joe
individually.
Thanks in Advance
Express Tools Layer Translator (LAYTRANS at the command line) would make you
smile - I think. 😉
Here's a Tech Support article from the Desker's Knowledge Base (in my
tinyurl) for your enlightenment j_seph. Mainly due to not being able to find
Help in the Express Tools. The index in ET Help had it listed, but alas
there was a notice re. "cannot display the webpage" on my attempt to click
it;
http://tinyurl.com/35675m
I've used it with much gratitude in my recent past. It takes a little while
to setup for each firm you get dwg files from, but from then on - it's
gravy. And I tried it out just now, and it worked OK with LDT 2K4.
HTH
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
CivilSeries-2K4
Intel Xeon 3.2GHz 2GB RAM
XPPro 32bit SP2
Nvidia Quadro NVS 285 256MB
"The only Constant is Change".
individually.
Thanks in Advance
Obviously it (LayTrans) wasn't previously part of your repertoire Joe. 😉
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
"Don Reichle" wrote in message
news:5461390@discussion.autodesk.com...
smile - I think. 😉
it;
HTH
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
individually.
Thanks in Advance
On nice thing about laytrans is you can save the layer translations to use
again. That's about as close as you will get to an EASY button with this.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
news:5461414@discussion.autodesk.com...
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
smile - I think. 😉
it;
HTH
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
individually.
Thanks in Advance
Thanks for mentioning the part I forgot to speak of John.
I was fairly sure it was in the KB article though.
(time passes during a check)
Underneath step 5, is where that is mentioned.
phew! 😉
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
"John Mayo" wrote in message
news:5461418@discussion.autodesk.com...
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
smile - I think. 😉
it;
HTH
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
individually.
Thanks in Advance
Tools>CAD Standards>Layer Translator 🙂 Been an AutoCAD command for quite
some time.
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
individually.
Thanks in Advance
Hey Scott;
Is Tools one of the menus that normally "hangs-out" on the newer releases?
IOW, anything past LDT 2K4, where it does n-o-t show up in either LDT or CD
2K4.
TIA
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
"Scott McEachron" wrote in message
news:5461461@discussion.autodesk.com...
some time.
sm
Scott McEachron
individually.
Thanks in Advance
hmmmm.... Thanks. I feel silly
Guess I've always had an affinity for writing scripts!
Joe
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
smile - I think. 😉
it;
HTH
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
individually.
Thanks in Advance
Whatever it takes to get the Project "out the door"! 😉
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
"Joe Bouza" wrote in message
news:5462176@discussion.autodesk.com...
Joe
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
smile - I think. 😉
it;
HTH
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
individually.
Thanks in Advance
It shows up as part of the AutoCAD menus, simply change to AutoCAD
workspace, or customize a workspace to add the menu.
sm
Scott McEachron
news:5461543@discussion.autodesk.com...
Hey Scott;
2K4.
TIA
Don Reichle
CivilSeries-2K4
XPPro 32bit SP2
some time.
sm
Scott McEachron
individually.
Thanks in Advance
