I open up a drawing and the point on the lower corner is 4.2E+09, -1.35E09. It is a simple 2D piping diagram. The scale on the drawing is correct. But if I zoom extents, it zooms way out and I can't see anything. I tried to search for a stray dot and erase it, but I can't find anything. How do I proceed?
>> But if I zoom extents, it zooms way out and I can't see anything. <<
try by ERASE command , then when asked to select objects type ALL then and now DESELECT your wanted and needed items by press and hold Shift + Left mouse button to keep it exist . now Zoom >> Extents and see if any changes . also i want to attract your attention for that Zooming in Model space have NO effect to the scale value in the contrary while you're in layout Viewports .
Imad Habash
I'll assume you had all Layers thawed and on and unlocked [and if you just thawed any, do a REGEN to make sure they all come up visible] when looking for a stray. But given that....
If you're willing to assume that whatever it is, you don't need it, one thing you can do is to ERASE and select ALL and then the Remove option, and Remove from the selection the stuff in the area that you want to keep.
If you Search for related terms, you will find other threads with the same (or nearly) question, and with other suggestions for fixing it.
And by the way, those coordinates are a heck of a long way -- billions of drawing units -- from the origin. That in itself can sometimes be the cause of certain difficulties, so you might try just Moving everything closer to the origin, in case that can help.
[And by the other way, the question seems quite different from the Subject line -- is there some mistake?]
Sometimes a stray dot won't select with a window selection. You can Control+A as suggested and that will select those stray dots. You can then hold shift and window select your drawing to unselect that part that you want to keep then hit delete and delete all the stray stuff. You might want to zoom into the stray stuff to see what it is first though.
Nick DiPietro
Cad Manager/Monkey
Great advice. My scale was in the millions, so I scaled to normal and the erase/deselect as you say worked and did the trick. The only thing is my drawing is at 9.0E+09 on the X-axis. Not too important to get it to 0,0 but if I wanted to re-position it to 0,0, hows is that done. No way to manually move it across 1,000,000 units.
@Anonymous wrote:
.... if I wanted to re-position it to 0,0, hows is that done. No way to manually move it across 1,000,000 units.
I don't see why not -- have you tried it?
The drawing is millions out from the 0,0 axis. I don't know how to even find 0,0. I am lost in space literally. Is there a command that will re-position my drawing to 0,0?
by MOVE command you can move all of your selected objects .
Command: m MOVE
Select objects: Specify opposite corner: 1 found
Select objects:
Specify base point or [Displacement] <Displacement>:
Specify second point or <use first point as displacement>: 0,0,0
Imad Habash
To elaborate a little:
Command: MOVE
Select objects: ALL
xxx found
Select objects: {press Enter to complete selection}
Specify base point or [Displacement] <Displacement>: {pick point in relation to objects that you want to be at origin}
Specify second point or <use first point as displacement>: 0,0 {that's your second point}
Then ZOOM Extents.
ok I figured it out. I use the move command, select the whole drawing then select displacement and type in 0,0,0 I
