Zones on the border of a d-size sheet. HOW DO I TURN ON THE ZONES SO THEY PRINT?
Message 1 of 13
I am trying to print so the zones show up on the border of my sheet. How on god's green Earth can I turn on the zones so they show up? PLEASE HELP!!!!!
Replies (12)
Message 2 of 13
imadHabash
from PLOT command , do all requirements and select the right Paper and scale then see if any changes .
Imad Habash
Message 3 of 13
That does not work. I just want my paper to print with the zones on the border. How do I get the zones to show up?
Message 4 of 13
imadHabash
would you please tell us about your attempts more .
Imad Habash
Message 5 of 13
I am using AutoCAD 2019. I have a 24" Hewlett-Packard Design-Jet Plotter. I have a drawing on a D-size sheet. I pushed the plot button. Everything looks great on the print preview except there are no zones around the border of the sheet. How do I turn the zones on?
Message 6 of 13
imadHabash
make sure that you're not using unprinted layer ( Layer dialog ) .
Imad Habash
Message 7 of 13
dgorsman
"Zones!"
"You keep using that word.  I do not think it means what you think it means."  Smiley Happy
Perhaps some screen shots so we are certain we're all referring to the same thing?
Message 8 of 13
Zones are the letters that are on the vertical borders of a sheet, and numbers on the horizontal borders.
Message 9 of 13
RobDraw
Check the layer properties that the letters are assigned to.
Rob
Message 10 of 13
In a sheet, do you have to draw the zone letters and numbers manually as part of the title block?
Message 11 of 13
RobDraw
Yes.
Rob
Message 12 of 13
s.borello
Post a sample file.
Message 13 of 13
ChicagoLooper
Please take a screen shot of your layout tab. Include everything in the screen shot, the entire white rectangle representing your D-size sheet and some of the gray area along the edges. Knowing what's on, in and around your D-size sheet will provide good info. Also, please take a screen shot of the Plot dialog window before hitting the Preview button. The settings for your plot job combined with the contents of your layout tab will provide a start that can be used to help you resolve your issue.
Chicagolooper
