Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Xref View port color
sagheerrahman
sagheerrahman
How to change xref VP color if object color is not set to by layer, if we use xrefoverride command linetype will also change, I want to change only object color not object linetype. Is there any other option to change only object color.
cadffm
No there isn't.
Only way, change the object properties in your xref file (to bylayer)
Sebastian
Valentin_CAD
@sagheerrahman ,
You may want to look into the Xref Layer Settings "Treat xref object properties as ByLayer":
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
sagheerrahman
No there isn't.
