AutoCAD Forum
Selecting a dimension shows as an mtext, line, and solid
1 REPLY 1
281 Views, 1 Reply
200581073
Observer
Observer
The problem is when I place a dimension, it separates itself into text, lines, and solids. Normally when I select it would show as "dimension. Can you help me with this problem? The screenshot below shows what happens when I select the dimension.
1 REPLY 1
ChicagoLooper
in reply to: 200581073
ChicagoLooper
Hi @200581073
Your DIMASSOC is 0.
0=no association between different dimension elements
Make DIMASSOC either 1 or 2.
1=creates non-associative dimension objects
2=creates associative dimension objects
Once it’s changed, perform dimension operation again.
  • If 1, the dim will not change if the if the object being measured is stretched or shortened.
  • If 2, the dim will react to changes in the object being measured. E
  • 1 or 2 will not explode your dim. The dim will be a single object.
Chicagolooper
Hi @200581073
Your DIMASSOC is 0.
Chicagolooper
AutoCAD Inside the Factory
