Xref Question
Xref Question
Message 1 of 21
Xref Question
Hello and thanks for reading to help me 🙂
I hope this makes sense, so i have 5 thousand drawings and i need to change the xref attached to the 5 thousand drawings to another xref that is in the same path. In other words i do not want to open 5 thousand drawings detach the xref and attach the other xref that i need. How do i do this please, ive tried LSP's and have had no luck please please please help me out. so the path doesn't need to be updated, the xref that the 5 thousand drawings are linked to needs to be changed. My quick fix was to just edit the current xref that the 5 thousand drawings are linked to so i can just do a batch PDF publish and then reverted it back to its original condition.
Thanks in advance
P.S the reason for why i want to attach a new xref and replace the old one is due to the fact that i am moving into a further stage in my project and the title block is different has more detail and some things removed.
Replies (20)
Message 21 of 21
RobDraw
What you marked as a solution is not going to help anyone looking for a way to replace some incidents of an XREF but not all.
Edited by
Discussion_Admin
Rob
