How do you turn on the xref manager dialogue box?
i just loaded 2015 Autocad and not seeing the dialoge box when i type in XR command.
classicxref seems to be working fine.
when i type in XREf is get the following:
C:\Program Files \ Autodesk \ Autocad 2015 \ acxrefesw.arx cannot find a procedure that it needs.
would using dual monitors be a cause?
Type in FILEDIA. If your FILEDIA setting is set to 1, then you should get dialoge boxes. If not, then CAD will be looking for file paths with xrefs.
type SDI press enter then change value to 1. now type xr enter.
just needed it too and figured it out.
cheers. Mike V
I am having a similar issue with one computer in my office. But it extends to the properties dialogue box and also the layer manager as well...
I am going to run a repair today, but I was wanting to know if there were any other tricks?
What is happenening is that every now and again, this morning it seemed like it was every other time I would open a new autocad, the properties dialogue box will not pop up and the xref manager wouldn't open either. Then at different times when I could get those dialogue box's to open the layer namager wouldn't open fully... It would be a small window at the top, but I am not able to stretch it or close it.
If I use the ._classicxref it works fine every time.
Any other ideas on what it could be?
