Xref ImageFrame Appears On Main Drawing
dcnkzr
dcnkzr
Hi Everyone
I have attached a few drawin into my main drawing, even  I have turned of image frame on all xref drawings, on main drawing tehre are still image frame frm xrefs I have tried all frame and clip off commend but it still there first imege is from my xref 2. image is from main drawing what is the reason for that and we work on sharepoint folder
imadHabash
@dcnkzr
Would you try with FRAME (System Variable) = 0 . ( Regen your dwg after modifying the value)
It's controls the display and plotting of borders for images, underlays (PDF, DWF, DGN), clipped external references (Xrefs), and wipeout objects. Its master values are 0 (hidden and not plotted), 1 (visible and plotted), 2 (visible but not plotted), and 3 (mixed settings).
Imad Habash
paullimapa
so you could also set FRAME to 2 so you can see but it won't plot
Paul Li
IT Specialist
@The Office
pkomatlapalli
Hi @dcnkzr,
We would like to follow up on this issue. Could you please let us know whether the responses provided by ImadHabash and Paullimapa helped resolve your problem?
If the issue has been resolved, we would appreciate it if you could mark the appropriate reply as the "Accepted Solution". This helps other community members who may encounter the same issue in the future.
Thank you for your time and assistance.
Pavan Kumar | Community Manager
