XREF Detail?
XREF Detail?
MaksSkuz27
XREF Detail?
MaksSkuz27
help? my XREF is missing the 'detail' portion of the property Palette. (contains info of where it's located, date, type, etc). I can't find anything about this.
AutoCAD 2017
thanks!
Alfred.NESWADBA
welcome @Anonymous!
Does it help when you move the XRef palette to another display and then resize it?
If you have not done too many customization's to your AutoCAD menus you might reset settings to default as described >>>here<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
-FDC-
What is that blue Arrow ?
imadHabash
>> my XREF is missing the 'detail' portion of the property Palette. <<
you can get it back if you right click down there ( green star ) then select Preview / Details Pane
Imad Habash
Alfred.NESWADBA
Wow, never have seen that ... 😉
- alfred -
Alfred NESWADBA
MaksSkuz27
MAN! thank you!!! i keep searching and clicking everything. *facepalms*
imadHabash
Good luck for you .. 🙂
Imad Habash
