Setting up Drawing & Layer Standards in AutoCAD
edlee
Message 1 of 16
edlee
@john.vellek
Looking for advice and resources for setting up CAD and Layer Standards for an organization that has never had any written SOP or documented AutoCAD workflow/process.
I'm also wondering if anyone has developed a basic CAD process flow chart or other graphical workflow material.
I work in a facilities department for a large transportation company with 40-50 properties of various sizes and functions, so we probably don't follow the typical AEC design processes.  But anything that I can use as a point of reference would be helpful.
Thanks in advance...
Accepted solutions (3)
Replies (15)
Message 2 of 16
john.vellek
HI @edlee,
Please find attached a sample file that follows the AIA layering standard.  I have also included my CTB file that will correspond with the layer colors.  If you change the color associated with a layer make sure you adjust the CTB file as well.
I will see what else I can pull together on the rest of your questions.  Obviously, each firm has its own workflow and preferences but perhaps I can get something put together that will help get you started.
John Vellek
Message 3 of 16
GrantsPirate
You might look here for an example.
http://home.planningoffice.harvard.edu/files/hppm/files/cad_standards.pdf
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 16
john.vellek
Hi @edlee,
Here is my table of Contents from one of the Office CAD Standards:
Each of these is a heading and contains additional sub-categories:
General CAD Practices
Standard Project Folders
Project Templates
Drawing Setup
Sheet Numbering
Titleblocks
Detail Sheet Setup
Page Layouts
Page Layout & Page Setup
Model Space - Paper Space
Layering Guideline
Drawing Stamp/Seal
Dimensioning
Text Height - LTscale - Dimscale
Door Insertion
Door Identification and Schedules
Wall & Wall-type Indication
Room Numbers
Symbol Legends & Lighting Power Budget
Pen Mapping
Printers and Plotters
BOMA Std Methods in Measuring Area in Office Buildings
Area Calculations
Area Calculations - Rules of Thumb
Master Facility Drawings
Master Facility Drawings Checklist
Marketing Plans
Menus
Regarding your workflow, if you can outline or flowchart how your facilities work process-wise I am happy to make suggestions.
Let me know if any of this helps or if you need more detail.
John Vellek
Message 5 of 16
edlee
@john.vellek
Thank you for the AIA layering documents, John.  Regarding the CAD workflow or flow chart, I'm just looking for any examples that I can use as a reference.
Thank you also for the CAD SOP outline.  It will be very helpful as a point of reference for getting started.
Message 6 of 16
edlee
@GrantsPirate
Thank you.  This example is very helpful.
Message 7 of 16
john.vellek
HI @edlee,
You indicated that you are in the facilities department. What kind of drawings do you maintain or develop? Do you work with consultants?  I am happy to help you with the flow chart if you can get me started with how you use your drawings and what their typical lifecycle looks like.
John Vellek
Message 8 of 16
melissacohen
I see that all the inquiries about layer standards are pretty old.  I am just getting started with my own office standards after doing whatever was convenient while in school.  I should mention that I am an interior designer and do not need a thousand layers and the layers might not be exactly what I need for ID.  If I start with the AIA standards, can you help me walk through how to load them?
Message 9 of 16
edlee
Thank you, John (a little delayed, sorry).  I appreciate your assistance.
Message 10 of 16
edlee
Thank you, GrantsPirate.  This is a useful reference document.
Message 11 of 16
edlee
Hello MelissaCohen.  I am an interior designer by education as well.  I am still working on setting up and documenting my organization's CAD SOP and Layer Standards, 2 years after that initial inquiry post.  I would be happy to provide you with any advice or information that I can.  We are in the same situation, because our corporate Facilities team is primarily focused on using AutoCAD for designing and managing the interior environments and furniture plans.  So the complete AIA layer package is much more than we typically need.
My main focus has been to try to implement a customized layer package that incorporates the AIA layer names with the NCS (National CAD Standards) layer guidelines.  I would be happy to share our interiors-focused layer standards, when I have them figured out.
I will see if I can attach some of the older NCS documentation that I found online (since I couldn't purchase the current NCS guidelines).
Message 12 of 16
melissacohen
I Apologize.  I somehow missed this post.  It must have seemed so rude to not respond!  I am under deadline at the moment, but I promise I will respond shortly.  Thank you for your generous offer!
Message 13 of 16
melissacohen
How is your progress?
Message 14 of 16
melissacohen
I am just getting to this now!  I will take a look!
thanks!
Message 15 of 16
melissacohen
I took a quick look.  Some of these posts are getting quite technical.  I really mean the following:
A-WALL-New
A-WALL - Existing
A-I- Furniture - Existing
Sink Fixtures, for example.  As an architect you want to have a layer for pipes, but as an interior designer, I just need to have a layer for my existing plumbing fixtures and a layer for my new plumbing fixtures.
Is the A and I necessary?  I just want to stick to one layering system.
Message 16 of 16
Graggs
@melissacohen
I think the prefix is important.
I have to work with drawings from all sorts of people and the time I waste trying to sort through layers is ridiculous.
The prefix helps enormously to give ownership of that layer to someone. It is also useful for yourself, used with Autocad's layer manager, you can quickly create filters to display only your layers or only the architect's layers for example.
