- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Recently we upgraded to Autocad 2018 and 2020 while getting new computers. Out of the 6 people in our office that received new computers and upgraded at the same time, only 2 of us our having the issue where typing 'Xref' or 'xr' freezes our computer instantly whether it is a new drawing, old drawing, or template. Oddly enough, if we use the command 'classicxref', the menu pops up instantly and works flawlessly. I worked my way down thru all the other xref related commands that auto populate when typing 'xref' and the also all work, with the exception of the xerf or xr. -xref works as well.
I put a version of 2013 on my same computer and it works great with all the xref, xr, and all related xref commands. All (3) versions are local installed versions that search for network keys. We have various servers, locally and remote at other offices that we work off of. I have checked the links and paths under Options Menu and they are all active. All service packs are installed. I have run the software as Administrator and the same result occurs.
Any help would be appreciated. Thank you.
