Message 1 of 8
XATTACH Dialog DWG preview disappears
Every recent version of AutoCAD I use gives me the same problem. When envoking the XATTACH command, there is usually a DWG preview to the right side of the dialog box. At some point over time that DWG preview disappears. I have to re-import the AutoCAD settings and that preview area of the dialog comes back. This happens in the current version I'm using which is 2015 but it also happened regularly in 2012, 2013 and 2014 and even farther back than that.
Is there a system variable like the FILEDIA that would reset that preview display to default?
Thank you.
