Wrapping an object around a cylinder
So I’m currently trying to building a fire sprinkler head and the frame is a bit hard to draw
I currently created a pie shape object that I lofted along a J shape path and the end of the path a cylinder needs to be connect es the pie shape object.
is there a way to wrap the lofted object or would I just extend to the put if trimming
dbroad
If I understand correctly, extend the loft into the cylinder.  Then union the loft and cylinder.
Architect, Registered NC, VA, SC, & GA.
