Align & Scale Issue
Align & Scale Issue
Align & Scale Issue
Hey Guys,
after a while i've started using AutoCad2018 again. I have two 3D Objects:
- a complex roof
- a simple rectangular solid
The roof is copied from a past draw. In the past I was able to use the align command, set 3 poinst to align the objects and scale them in accordance to the alignment points with 1 command (align^^). The align itself still works fine, but after choosing 3 points im not asked if want to scale as well. Is there still a command for that? If not, does anyone have a good alternative for me? 🙂
LB
imadHabash
To get the scale option while Align command is active you have to use two points and when asked for Specify third source point press enter to get the scale optionScale objects based on alignment points? [Yes/No] <N>:
Imad Habash
Thank you, it works. Anyway a 3 point align + scale would be more sufficient. Is there a possibility?
imadHabash
Nop .
Imad Habash
